jetcare
Nov 25, 2016Explorer
You have the newer Single Zone Dometic digital thermostat that is communicating with a control box (gray in color) located behind the ceiling assembly filter. As you said, 12V+, 12V- and comm. You will not be able to use a different style thermostat unless you revert back to an older style control box and run more wires to the thermostat.
I find the Dometic digital thermostat to be very accurate. You need to replace the Dometic digital thermostat and see if your issue goes away.
Dometic PN: 3313192.000 for white and PN: 3313192.019 for black. Only $30-$35.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
