KeithE wrote:
Hello! I wonder if anyone can help me with a problem I've been unable to solve for over a month. I recently purchased a new Dometic 15k BTU A/C and new LCD thermostat. My coach has an existing furnace that needs to be wired in to the new control box. The new control box has 2 blue/white wires to connect to (and control) the furnace. The furnace has 2 wires (a red and a white). I presume the blue/white wires get connected to the red and white wires, but ... does it matter which gets connected to which? I'm utterly desperate to figure this out: Dometic is useless, the instructions are useless. Thank you so much for any help you can give!
It doesn't matter- the two wires on the control box simply go to a relay- open or closed.
