time2roll's avatar
Mar 23, 2013
Dometic digital thermostat
Been wanting to go with a digital thermostat but I was not very excited about using the battery powered home units for the conversion. Then found out Dometic has a new thermostat and control board.
So if you have this thermostat:
And you want something like this:
(I fixed those extra holes BTW)
Here is the kit:
Dometic Single Zone LCD Control Kit w/ Thermostat White 3313189.000 $75
Here is the kit pictured:
clockwise from top left. freeze sensor, spade terminals to crimp onto your furnace control wires, wall thermostat, mounting screws, control box, wire harness.
This is the old box up in the air unit
Here is the new box. Much smaller should also allow better air flow through the inlet filter.
Old box with the gaggle of wires. Actually fairly simple.
Paired white/black are 12v supply.
Blue/white is control connection to furnace.
Yellow is 120v power bundle.
Black to the left is the freeze sensor.
Brown is the bundle from the old thermostat.
Everything is either cut or disconnected to remove the old box.
New box connected to romex
The kit comes with a wire harness to connect to 12v and the thermostat cable. Only three wires are used for the new thermostat. 12+, 12-, & one control wire. I used Red, Black, Orange as that matches the harness.
This is the new box with snap connectors:
The heater control wires connect to the two spade terminals on the left. Thermostat control harness snaps into the four pin middle connector. Freeze sensor on the two pin connector to the right. Romex goes in at the far right. Power and control to the air conditioner uses oem harness that plugs in on the back side.
Worked perfect right out of the box. Well OK I had to buy some spade connectors as the oem wire to the furnace was a larger size. And some crimp connectors (not included) to connect the 12v thermostat harness.
Here is the user manual for those that want more operating details:
Dometic single zone digital operating instructions
Inspired by member BuffaloIndian in this thread:
Anyone Replaced Dometic Thermostat: Analog to Digital?
