There is a sort of foil-covered foam insulating board (or something similar) on my fridge adjacent to the panel, which is presumably what it's taped to. The actual panel is fairly thin. Mine weren't taped on, or if they were the tape had since ceased to be adhesive to any noticeable extent.
I actually removed it precisely to stick on a vinyl self-adhesive whiteboard material, the thin stuff that comes on a roll. I figured I had sufficient woodgrain elsewhere in the motorhome, but no place to jot down notes and shopping lists. I did have to make a little border around the whiteboard stuff (I used patterned duck tape, though I'm not convinced that is the ideal solution) as the vinyl roll was about 1/8 inch too narrow for the door.
For the whiteboard, at least, it would have been a bit better to have primed the panel with white paint first as the vinyl is just a teensy bit shy of being truly opaque. It works reasonably well on the whole, though. Good quality whiteboards do erase more readily than the vinyl sheeting, but are also a bit more costly.
