tlaffourtit's avatar
Oct 28, 2022
dual transfer switch
is it possible to have 2 automatic transfer switches within the same circuit?
Presently i have an automatic transfer switch between the generator and shore power, and a manual switch between those circuits and the inverter, then to main panel.
i would like it to be automatic in both cases. thoughts?
i will post this on 2 other sites just in case you might see my question there also.
Tim
  • thanks for your thoughts. i will remove the one manual and add the second ats.
  • I converted my 30 amp coach to 50 amp when I installed the cord reel.
    I have 2 auto transfer switches.
    A 50 amp for the shore power and all else that feeds the breaker panel.
    A 30 amp (existing)to transfer from gen set to inverter and feeds the 50 amp switch.
    Totally automatic transfer!!:B
    One thing to be aware of is the fact that you will have 2 delays stacked.
    This caused some concern when I first tested!!:o
    Housted
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
