coruss's avatar
coruss
Ecoworthy 20a settings?
I just installed an ecoworthy 20a controller and a 235watt panel. I have two Trojan 145plus 6v batteries.
A few questions on settings:
-For the Bulk, Absorb and float voltage settings I was planning on using 14.8, and 13.2 per the battery spec sheet. What should I do for the float voltage?
-"Over discharge protection voltage".....Not sure what to do here?
-"Discharge restart voltage".....Again, not sure?
Thanks for the help
  • You may have blown the controller when connecting everything
    If you did not follow procedure
    Connect batteries first
    Then connect panels to controller
    If you connect panels first, it sometimes blows the controller
    Check for reverse connections,
    Check to make sure you used the correct terminals
    Some controllers have six terminals
    Load terminals are for a light or dc motor, Not for the batteries
  • Anyone?
    Also it seems the controller is not working. The panel is mounted flat so the sun is at a pretty steep angle, but even so the controller stays in sleep mode and is not putting out any amps. I placed a load on the battery and still nothing.
    The voltage on the controller is correct until you hook up the panel then it drops by about .8 volts. Multimeter still reads 12.5v at the batteries.
    I have 38v going into the controller, but nothing coming out?
    Any ideas?
