Playtime_II
Jun 24, 2013Explorer
Original owner had a desk with drawers installed instead of the second couch. The knee hole was the perfect width for a FP. I bought the FP at HD and removed its wooded cabinet. The problems I ran into is that the fireplace draws in cool air from the top. I added grills to front then blocked the center so the FP heat would not just recirculate. The knee hole also had a extended floor register from the furnace vent the originally terminated on the side of the kitchen counter. I just extended it to the front and built a base to rest the FP on. The 110v was pulled from a junction box that did not use Inverted power. This FP only draws 1200w so I shouldn't overload the circuit. I can select the "Flame" i.e. bulb only or heat and flame. The heat is also adjustable. Quite too.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
