- GoostoffExplorer
Here is the before.
- myredracerExplorer IIAnother option is to install a kickspace heater below the range. One benefit to this is that the space under the range is 100% unused dead space and you won't lose valuable cabinet storage. There is one brand that is the exact same width as the range.
- empty_nestExplorer
BB_TX wrote:
I installed one in our little used cabinet under the TV. Bought one from electricfireplacesdirect.com that almost perfectly matched my opening with no cabinet modifications. Just added a base for it to sit on, a new electric outlet, and some trim purchased from Lowes.
Before
During
After
Thank You. That is really nice-looking. That's exactly what we had in mind. - the_bear_IIExplorerNice job.
I did a similar mod in my 5th wheel. Took out a drawer and a shelf area under the TV cabinet. Put in an electric fireplace. Used the electrical outlet behind the TV to plug in the fireplace.
The heat unit on the fireplace helps to keep the 5th wheel comfortable on cold nights and mornings. - brireneExplorerMany have done it, and there are many posts here on the subject. Never seen anyone who referred it. Search 'fireplace' in the search box above. Happy trails!
Edit: "regretted" it. :S - BB_TXNomadI installed one in our little used cabinet under the TV. Bought one from electricfireplacesdirect.com that almost perfectly matched my opening with no cabinet modifications. Just added a base for it to sit on, a new electric outlet, and some trim purchased from Lowes.
Before
During
After
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
