zaheer22's avatar
zaheer22
ELX-45 Main Breaker.
Hello,
Not sure if anyone has done this before, But I have a recently acquired 2007 Palomino thoroughbred that comes with a main 20 amp main breaker. Using electric heat and the Electric water heater has resulted in the breaker tripping every few hours ( as the Water heater cycles on). I was doing a little head scratching as I had 30 amp service. After some digging in the manual I discovered Palomino used a 20 AMP main breaker in the Elixir 45 amp converter. Now after even more research, I discovered the Elixir 45 amp manual calls for a 30 amp main. Not wanting to set anything on fire I pulled the converter and lo and behold the main incoming wire is sized for 30 AMP. Does anyone see any reason NOT to swap out the main to 30 amp?
  • If ALL the wiring to the panel is 10 gauge wire AND the panel can handle 30 amps, then I see no reason you couldn't replace the main 20 amp breaker with a 30.
  • Hey All,
    I lose ALL AC power. I know when it flipped my laptop stopped charging, and so did my iPhone both running off of AC power. When I pulled the converter, the RV power cord was indeed wired to the 20AMP breaker, and this is consistent with the palomino manual that states the main is 20AMP. Seems like , 30AMP is the way to go as the wires are good for it.
  • enblethen wrote:
    Do not confuse the main breaker with the branch breaker feeding the converter.
    Some rigs do not have main breakers. The shore power cord goes to the buss work.
    THIS^^^^^^^^
    Elixir did that a lot........RV power cord going straight to buss w/o Main Breaker
    That 20A CB that keeps tripping.......when it trips do you lose ALL AC Power or just water heater ?
    When you pulled converter was your RV 30A cord wired thru that 20A CB?
    If 20A CB IS the Main Breaker than yes you can use 30A.....IF!!!
  • Thanks,
    I did trace the wire and that is how I know it is the main breaker. It is a 20 AMP and the Palomino manual says it is the main as well (20 AMP) What I am struggling to understand is why when the cable and service is rated for 30, did they choose to go with 20 AMP. I did validate the Branch for the converter is a 15AMP, so I know the 20 is the main. I want to use the trailer for some winter camping so If I could have electric Heat and run a 1500W heater simultaneously would be great!
  • If you have the standard 30 amp shore power cord, go withy the 30 amp main breaker. Cord should say on it what gauge of wire. It should say 10/3 and be able 3/4 inch in diameter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Mar 11, 2026
