profdant139
Feb 07, 2018Explorer III
I have found a few "underbelly build" blog posts where folks have used aluminum panels to span from one frame member across to the other side, using self tapping sheet metal screws into the web of the frame beams.
I am not sure that this would have the strength or rigidity to support foam insulating panels, but it is a simple solution.
What do the "four season" manufacturers use on their underbelly enclosures?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
