blawless
Jan 15, 2016Explorer
I replaced mine last year with tinted Lexan. Use silicone to glue the lexan to the frame ( if your frame is black like mine use black colored silicone, if white use white or clear.) Set the frame flat and line the channel with silicone then press the lexan gently onto the frame. The key is to leave it alone and let it dry overnight. Then use butyl tape to seal the frame to the door. Mine is still nice and tight, no leaks and it looks great. The lexan matches the tint on the other windows.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
