blawless
Jan 16, 2016Explorer
For the Lexan regular silicon works very well. If you were deciding to replace the window with tinted glass, being heavier and non flexible, butyl tape cut to fit the channel would be better as its not as secure and allows the glass to flex within the frame. The frame has a channel as well for adhering to the door, I used a 1/4 " butyl tape cut to fit the channel portion that adheres to the door. Don't try to seal the entire frame, just the channel as it was designed. The frame will fit nice and flush and also be water-proof.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
