Mickeyfan0805's avatar
Feb 28, 2018
Eternabond over sealant?
Our unit just turned 5 and is holding together beautifully. I want to keep it that way!
Over the past 5 years, I have done both spring and fall seal checks, placing self-leveling sealant over any locations where I found a crack. Now that the original sealant is 5 years old, I'm starting to consider moving to eternabond, but I'm not sure about putting it over the uneven sealant that is there.
For those of you who use Eternabond around your trailer, did you remove all of the sealant or simply place it over the existing and while making sure to get a clean seal on the edges?
