WDP
May 14, 2014Explorer
Received the ICM Controls ICM102B timer and it works. Took about 5 minutes to install, moved the thermostat fan low connector to the relay, made up a short jumper back the the control panel. Secured with a screw to the interior of the air filter plenum. Set at minimum, I get 2.5 seconds of delay, the adjustment is not linear, a small increase jumps the delay to 20 seconds. Maybe a bad unit. I turned off the converter and ran the batteries down to 11.35 volts and it still timed and latched reliably.
WDP
WDP
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,405 PostsLatest Activity: Apr 20, 2026
