- yatyas81ExplorerI used reversible beam clamps to attach mine ($1.99 ea). They clamp on to the frame and have a threaded hole to attach a bolt. 4 clamps, some all thread, nuts and washers and 2 pieces of pre-drilled flat stock holds it in place. The best part is you can easily relocate it if you need to by moving the clamps.
- prowlerregalExploreryatyas81 where did you buy the reversible beam clamps?Would home depot or lowes carry these? Can you post a picture or two of your install? Thanks!
- yatyas81ExplorerLowes has them in their electric dept. They're used to hang conduit from I-beams.
- yatyas81Explorer$1.95 at Lowes
- Houston_RemodelExplorerNagrompj ,
What us the white cradle the hose sets on? That's what I am looking for - camperforlifeExplorerI believe the cradle is a section of plastic residential rain gutter.
- rhagfoExplorer III
It is and the only place I have seen the U shaped is Loews. - prowlerregalExploreryatyas81 thanks for the pictures.I'm going to lowes tomorrow.
- Houston_RemodelExplorerI'll see you there Prowler
- steelpony5555ExplorerI used 6" pvc sewer pipe with some all thread and angle iron. The PVC sewer pipe is a whole lot sturdier. Also used the gutter to pull it in and out.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 19, 2025
