time2roll
Apr 28, 2018Nomad
Verify the equipment and fixtures are rated 120vac before you pull wire and connect. Most RV lights, pump, fans etc run on 12 volt battery power.
Use regular stranded primary wire for 12v systems... not romex to avoid confusion.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
