Lwiddis
Apr 28, 2018Navigator
All TTs are wired the same. It’s basic. A 12 volt system for some things that uses the battery/ies or is fed by the converter if plugged in, and a 120 volt system that runs items like the A/C and microwave and feeds the 12 volt system when plugged in. Before you wire anything do extensive reading.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
