Tin_Pusher's avatar
Tin_Pusher
Explorer II
Sep 01, 2015
Finally Figgered It Out
So, when you're putting the A/C grille back up after washing the filter, you're standing on your tiptoes, holding the grille with one hand, starting the screws with the other, wishing you had a third for the screwdriver, trying not to lose the screws down the floor vent...
It suddenly came to me:
Any kind of thin plastic will work :)
  • "Golf - criminal misuse of a perfectly good rifle range."
  • LOL, P.J. O'Rourke "Its a lot easier to shoot a deer on a 350 yard par-four fairway than it is in the deep woods."
  • Wooden kitchen matches glued into the old screw holes works well too.
    It really depends on the thickness of the material where the screw has stripped out. If it's 3/16" ply you really need a bigger screw or a moly bolt. Filling holes with wood pieces & glue only works on much thicker stuff.
  • I've used dowels to repair screw holes for reattaching door lock strikers and striker plates. Drill hole, put wood glue on dowel, shove in hole, cutoff excess, let dry and drill new hole.
    I bought a package of small wood dowels in various diameters that were about 12 inches long to add to my onboard trailer repair kit. I think I got them in the arts and craft section at Walmart. You can also find wood dowels at hardware stores but the shortest are about 36 inches.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
