- Camp__Forrest__ExplorerAw man. When I saw the thread title, I thought someone was making an RV out of a Bowler Wildcat offroader. I can't do links from my IPad, but if you search Bowler Wildcat you'll find it. If you have Netflix, there are two Top Gear episodes featuring it.
- filthy_beastExplorer
Old-Biscuit wrote:
NICE job on that pin box.
Had to enclose the one on last 5'vr to keep the wasps from setting up home.
Haven't needed to on this 5'vr cause we travel FT and rig doesn't sit long enough for any 'home building' plus I store umbilical cord inside pin box.
That's a good safe. Where you able to bolt it 'thru' the floor?
As your signature says "You cannot make things idiot proof, you can only make them idiot resistant"
So true....very true :B
Yes, it is screwed to the floor. I ripped down some 2x4 and countersunk screws through them into the floor. Added plywood screwed to them and the safe is bolted through the plywood. - Old-BiscuitExplorer IIINICE job on that pin box.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Nov 08, 2025
