fred42
Dec 01, 2017Explorer
MrWizard wrote:
wouldn't removing the screws from the hinge on one side
have allowed the middle panel to open and close with out cutting the hinge?
I was hoping that would be case as well. However, when I removed them, there was too much pressure on the door from the unwanted hinge arm and especially the pin. The pin was permanently attached, It may have been possible to cut the pin with one of those dremel tool metal disks, but I could not find mine. When in use, you will need to open the door by putting your hand right where the unwanted hinge arm was.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
