popeyemth's avatar
popeyemth
FloJet macerator
Recently bought a FloJet and would like to pump into a plastic barrel in the bed of the truck and take the barrel to the dump station and empty.
What I'd like to do is adapt a regular RV dump hose to the bung on the drum and use a Valtera style valve that comes on campers .
Does anyone know how Or where I can get a valve that will screw into the bung ?
Thanks,Mike
  • SoundGuy wrote:
    Desert Drew wrote:
    For long term boondocking a few 6 or 7 gallon containers may not be enough, and I for one, would not want to have to lug them around. A 55 (or 35) gallon drum can be secured in the bed of your truck, filled and gravity drained without ever having to move it.
    What's the difference between a 35 gal drum mounted in the bed of a truck and five 7 gal Aquatainers? Easy answer - that 35 gal drum will weigh ~ 300 lbs when full :E while a 7 gal Aquatainer will weigh 60 lbs and is easily lowered from the truck bed to a dump station sewer pad ... tip the 'Tainer to drain it and you're done, no "lugging" anything around, no need for fittings or drain hoses. Total capacity can be as great as you want it to be, determined solely by the number of Aquatainers you have - cube shaped, easy to store as there's no wasted space. And when you're not camping what do you do with that big drum? ... leave it in the truck only to be in the way all the time? :S
    Fulltimers don't unload.
    I understand your position, it is valid if you don't mind lowering 60 lbs. to the ground times how ever many containers you have. With the drum all you have to lift (sort of) is the hose and you could even leave that hooked up.
    The OP said in his opening post -
    "Recently bought a FloJet and would like to pump into a plastic barrel in the bed of the truck and take the barrel to the dump station and empty."
    The OP said nothing about being a "fulltimer" and is clearly talking about camping in conventional campgrounds ... my response is in kind, questioning why anyone dumping at campground dump stations would want to drag around a single large tank when a few inexpensive Aquatainers are so much easier to deal with. To each his/her own but a heavy tank makes no sense to me. :R
  • "When you are finished filling the barrel, how do you prevent back flow from coming back down the hose towards the pump?"
    First, there's the 1-1/2" gate valve on the bottom of the barrel.
    Second, each end of the 3/4" hose from the Flojet to the barrel has a full flow garden hose shut-off valve on it. I ordered the full-flow valves from Amazon since the local big box stores didn't have them.
    Actually, when the gray TT tank is empty the Flojet will pump air and it will blow out the 3/4" hose. So if you close the valve at the Flojet, shut it off, and close the two valves at the barrel there's very little water left in the line. You do have an ounce or so in the Banjo fitting when you disconnect it. That's why I flush the line with gray water after I run the black tank out.
    All the plumbing and pump are in the TT. As soon as I get it back from the repair shop (another story) I'll post some pics on my Webshots page.
    Please post here or PM me when you get pics
    Thanks,Mike (original poster)
    Thanks for the reply. I wondered if the pump would blow the line clear.
