ha anyone here ever put electric heat blankets under their rv flooring? Supposedly, it is only 1/8 thick so if you were replacing carpet with Allure it should fit.
I could use some clarification on the difference between an electric heat blanket and an (electric) heated floor element. Would these be 110 volt units?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
