thoms's avatar
thoms
freezer door seal
Does anyone know where can I get a replacement door seal for a norcold N611 freezer door? checked all parts sites on internet but no seals???
seems this should be a common replacement DIY?
Thanks to all
  • Old-Biscuit wrote:
    Norcold Fridge Door Seals are NOT replacement items.
    They are incorporated within the door
    So Norcold wants to sell you a complete new door!
    Folks have cut the old seals off and used glue on / self adhesvie generic seals
    Sometimes you can 'reset' the seals
    Place a cotton ball in each corner under the seal
    Heat the seal using a hair dryer, warm air heat gun etc until the whole seal is warmed up
    THen close door and let seal reform to fridge frame
    After it cools remove the cotton balls and check if sealing has improved
    I like that trick!
  • Norcold Fridge Door Seals are NOT replacement items.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
