Lynnmor
Dec 14, 2013Explorer II
ford truck guy wrote:
On ours , the tank is just about up to the floor boards , with the hose running out the top and straight down. There is no where for it to go up...
I replaced the tank with one that had an inlet on top right under the dinette. From there I ran the pipe outside.
If there is no way to go up where the pipes are, then attach long hoses to the current vents and run them to where you can go higher. Install low point drains as needed in the hoses.
Whatever you do, don't install valves to close off the vents, that is an accident waiting to happen.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
