Lynnmor
Dec 15, 2013Explorer II
Ford truck guy, You can take any advice you want, but it is not safe to pressure fill your tank without vents that are two times larger than the supply line. The fresh water tank is not a pressure vessel and will fail at very low pressures. City water pressure can be anywhere from 30 to 100 PSI and that can and will cause severe damage. The frame, floor and tank may be damaged. It is irresponsible for anyone to give advice that may cause you severe problems. It is also irresponsible to sell or trade a unit that may cause others harm.
Again, it is not a siphon.
It is a spill.
You must vent the tank well above water level.
It is a spill.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
