Gjac
Dec 16, 2013Explorer III
To all those that have installed ball valves to prevent siphoning I would caution against this. I Guy I traveled with for a while did this and when we pulled into a FHU CG he forgot to open the valve before he switch his city water valve and the pressure build up in the FW tank caused the tank to swell and it broke the supporting structure. I took a half a days work and a lot of FG repair to fix. I fixed my problem by raising the over flow hose above the tank to break the siphoning effect, It is an easier fix especially if you are older and forget to open the ball valve.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
