Old-Biscuit
May 18, 2015Explorer III
westend wrote:
How long did the fridge operate before it was deemed broken? If the freezer section is working, wouldn't that mean that the cooling unit is functioning?
Edit: reread the original post and I see that the freezer section is not functioning. Sorry about the bad info above, I'll need to reread post before I comment.
Residential 120V replacement may be a cheaper cost than replacing the cooling unit.
Freezer can get down and food section not...........blockage can occur in between the 2 different evap sections.
SO always determine if fridge is working by checking food section temps
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
