kaydeejay
May 18, 2015Explorer
Old-Biscuit wrote:My first trailer was a 1984 Prowler that was permananently parked in a Campground in Ontario. It was dead level and never moved.Failure mode is the same as one in a previous trailer. Diagnosis then was a blockage in the cooling unit.2 trailers.....both fridges cooling units blockage :H
You might want to review/revise your way of operating fridges.
Off level operation even for 20 minutes can cause overheating of coolant which then crystallizes. The crystals then plate out on tubing like a plague--------permanently. This damage is accumulative
I then owned a Class A followed by a Citation fifth-wheel and had no problems.
My current one has been the traveler, but I have been meticulous about leveling it when parked.
Not sure what else I could do.
This last one is 16 years old. I suspect it may have been on borrowed time :B I have owned it since 2007, I have no idea how it was treated for the first 8 years.
It was working perfectly when I shut it down to Winterize last Fall. It failed to start up when I turned it on last week. I had even leveled it for Winter storage!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
