Chris_Bryant
May 19, 2015Explorer II
To the original question- a friend of mine is now a distributor for Arcticold- I've looked at them a bit, and done some control work on some with these units. They look good, use thicker wall tubing than stock, seem to work well (the 1200 I worked on would maintain 30 degrees in the bottom compartment).
I won't give an opinion vis-a-vi the Pines "Amish" units- not enough experience for an opinion.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
