kaydeejay's avatar
kaydeejay
Fridge died! Are Arcticold units OK?
Had a buyer lined up for my fiver but promised to de-winterize and check everything out before we met up.
Wouldn't you know it - the fridge (Dometic) is not cooling.:M
Freezer is cool but not freezing, rest of the fridge is room temperature.
Arcticold will sell a new (not re-manufactured) cooling unit for $580 plus $50 shipping with a lifetime warranty. No return of the old unit required.
Any experiences with this company, Good or Bad?
  • Chandalen wrote:
    Did you try it on Gas vs. elect? The whole thing may not be broken.. if you can live with it working on gas.
    Gas or electric - no difference. Plenty of heat in the heater/burner area.
    Failure mode is the same as one in a previous trailer. Diagnosis then was a blockage in the cooling unit.
    I took the fridge out and rolled it over a few times and actually got it to work - for a whole 2 weeks.
  • Did you try it on Gas vs. elect? The whole thing may not be broken.. if you can live with it working on gas.
  • How long did the fridge operate before it was deemed broken? If the freezer section is working, wouldn't that mean that the cooling unit is functioning?
    Edit: reread the original post and I see that the freezer section is not functioning. Sorry about the bad info above, I'll need to reread post before I comment.
    Residential 120V replacement may be a cheaper cost than replacing the cooling unit.
  • 2oldman wrote:
    A few posts with Articold in them
    Thanks.
    I did see those but the experience seemed a bit limited.
    One poster canceled the order as they never responded to him.
    I was hoping for a few more positives (if they are out there)
