So has anybody tried using a 12V computer fan tied across the gas solenoid? The fan would run only when the gas burner was on. And / or using a 115V fan across the heater element?
Problem with the fan across gas selenoid is it would run even when it was extremely cold outside. Plus the fan should run when fridge is hot even if it is on electric.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
