So has anybody tried using a 12V computer fan tied across the gas solenoid? The fan would run only when the gas burner was on. And / or using a 115V fan across the heater element?
I did the same as rod knocker. You need airflow over the cooling unit fins when on gas or electric. The same amount of heat is present on either mode. Using a fan switch at around 90 degrees is the way to go. Be sure that you use a manual on-off switch or the fan will turn on when temps hit 90 degrees even if the fridge is off. Mine is a 12-volt dc computer fan.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
