popeyemth's avatar
popeyemth
Fridge Fan Results
Recently posted a mod to install thermostatically controlled fridge fans but the spring like weather here :) and where we have travelled did not not present a real challenge for the fridge.
This past week we returned from Minnesota through St Louis when the thermometer downtown hit 102 :(
You can tell from the pic the fridge fans were a big help.
Last year without the fans and similar temps the fridge stayed in the low 50's and the ice cream was mushy.
  • Thanks bob213
    I have the 507 TPMS and this model uses 433 MHz. I am not sure if the 510 TPMS also uses 433. I don't think the sensors work with both models, so I am GUESSING the 510 is on a different frequency.
    Robert
  • 100ton:
    I have the TST (TPMS)system(unbelievable customer service by the way) and the same thermometer as pictured. Mine do not interfere with each other and both work correctly.
  • popeyemth wrote:
    Love my remote thermometer that we can watch while driving.
    Seeing the temps are ok makes one less thing to worry about while driving - like "is the ice cream getting mushy? "
    I also added a couple of fans (top and bottom), it does help.
    Sorry for "hitching on you thread."
    Just wondering if you (or anyone else) have a tire pressure monitoring system and a remote thermometer, and have experienced any issues with interference between the two. I think most, or all remote thermometer units operate on 433 MHz. My TST TPMS uses the same frequency.
    I have not found this to be a problem over the years, however, lately I have been having some boot issues with the TPMS. I have heard this can cause cause a conflict with the TPMS, don't know if it can affect the thermometer in some way.
    What say you?
    Thanks,
    Robert
    Huntington Beach, California
  • Love my remote thermometer that we can watch while driving.
  • tvman44 wrote:
    Where did you put the fans, inside or outside?
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27607341.cfm
    Both :)
    That's because ice cream goes in the freezer;)J/k Glad the mod worked
    Ice cream goes in Grandpa :)
    Usually none left I take pretty good care of it :)
  • Good to know that the fans helped, thanks for sharing the results of your efforts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
