This may be the wrong place to post this not sure. I am looking to add a 12v fan to the fins on my fridge but not sure if the fan should blow at the fins or away from the fins?
I was just doing some reading about fans outside the unit in the working area and they were talking about the type of fans people use out there. if you have a ball bearing fan you can mount it horizontally and if you buy a sleeve bearing fan only mount it vertical. I bought a four pack so I'm not going to worry too much about how I mount mine in the space out side. the fans are computer cooling fans.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Jul 13, 2016
