jjj's avatar
jjj
fridge fans
I had a computer fan blowing air from the bottom of cooler unit but last week it died. I started up the fridge on monday and Wednesday I went to check it is was in low 50's so I changed to propane thought it would cool better and went in yesterday to load it was at 60. It was 105 outside and 100 in the fiver.I have a 9 inch house fan that I put in the compartment for a temp fix and got it to drop to 42 within 3 hours.The fans work so what I would like to know where to get a couple good quality fans to put in there for a permanate fix that will last a few years. Thanks
  • how much heat does a fridge generate when the burner is off? does the fan need to run all the time, or can it wire into the burner relay?
  • Suggest you get a blower motor fan like this one
    http://www.digikey.com/product-detail/en/PMB1275PNB1-AY.%282%29.GN/259-1365-ND/1021214
    Additionally to reduce fan speed / noise when not needed get a nice adjustable PWM speed controller - The ones on Ebay for $5.00 or so work great
  • All Electronics is in Van Nuys and open on the weekends. They have a wide selection of sizes, volume/ current, voltage, and guards for all sizes.
  • A few sources for good prices on good fans:
    bgmicro.com ... allelectronics.com ... mpja.com ... www.goldmine-elec-products.com
  • Any computer shop or electric shop should be able to come up with 12 volt fans. Check e-bay for 12volt muffin fans
    Here is where I bought mine...RV Frig Fans....HERE
  • This is a Fridge Fix that might cure your issues - http://smartrvproducts.com/
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
