I am searching for ways others have secured their generator, specifically when mounted to a receiver hitch tray. I made my tray, but have only come up with a slightly complicated way to lock it on, o...
Fasten the generator to the mounting frame with U-bolts. File off the points on one facet of the hex nut used to tighten the u-bolts. Make sure you have the correct size 6 point socket to loosen the U-bolts, should it be necessary. Thieves are masters of opportunity so will leave if a twelve point socket is used or if getting access to the connectors is a problem. Make it a problem.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
