- westendExplorerI had good luck with Sherwin Williams Industrial DTM primer over both bare aluminum and other painted surfaces. It is listed for both types of surfaces.
- MootpointExplorer
dockmasterdave wrote:
If you are painting on bare aluminum it would be a zinc chromate primer.
It has an acid component and etches into the metal.
If you are paining over paint any auto primer should be fine.
It comes in different colors to make it easier to cover over.
If you are painting a decal, I can't help there.
Good luck.
X2 on that.
Also check what primer is recommended for the paint. - dockmasterdaveExplorerIf you are painting on bare aluminum it would be a zinc chromate primer.
Good luck. - imgoin4itExplorerI would go to a good auto paint Store and ask them. They will also have any equipment / supplies you may need. Additionally they can match the color of your truck. I have found them very helpful in the past.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
