Phydeauxman's avatar
Phydeauxman
Gooseneck Recommendations
I currently have a PullRite auto slider hitch that I want to replace with an Andersen Aluminum Ultimate 5th Wheel hitch. The Andersen is a gooseneck hitch so I am looking for recommendations for a gooseneck hitch that I can install in my 2014 F250.
  • The rail version is still a steel frame. The aluminum is only available as a gooseball attachable.
  • spud1957 wrote:
    There is an Andersen 5th wheel hitch that fits standard rails and comes with an adapter that bolts to the pin. No gooseneck ball needed. Are you wanting a gooseneck ball in your truck for other uses?
    I think they only make the aluminum in the gooseneck variety...and now that I have researched it some...would love to have the clean bed that I can get from using the gooseneck.
  • I recently bought a used Ram 2500 that has a welded NAPA gooseneck ball installed. I am removing that and installing the B&W turnover ball to go with my aluminum Andersen Ultimate as I want a flat, unobstructed bed when the hitch is out.
  • I think most people use the B&W turnover ball with the Andersen 5th wheel ultimate.... They don't refer to it as a gooseneck hitch because it raises the ball to the 5th wheel level and there isn't a gooseneck to reach the ball.
  • ralphnjoann wrote:
    kaydeejay wrote:
    Just be sure to check with your Manufacturer that your fiver frame can take the substantially increased stresses of a gooseneck.
    If a new fiver, it MAY void the frame warranty.
    There won't be any "substantially increased stresses" with an Andersen.
    OK, I stand corrected. Watched the Anderson video. Looks good.
  • I have the B&W turnover ball and like it very well. Allows you to have a flat bed when not hauling and has the best frame mount IMO.
  • Just be sure to check with your Manufacturer that your fiver frame can take the substantially increased stresses of a gooseneck.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Nov 08, 2025
