- donhoward49ExplorerI may be late on this post, buy yes it can be dune, even on a National where a plate is in front of the bell crank. I was working just by feeling around. I drilled it small, then bigger, then used a flat tap to thread the cert.
- Clay_LExplorerI installed one on mine. I couldn't raise the shaft up as high on mine as Omeys info said I could. There is a metal piece over it in the way.
I had a friend with a blind tap that let me tap the hole without damaging the shaft. - cmarqExplorerThere is a article on how to do it on Omeys website. This is a excellent source of info for workhorse parts and mods
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
