Old-Biscuit
Mar 31, 2014Explorer III
Do all tanks drain thru one common drain line?
I install another drain valve on main drain line just before the sewer hose connection.
With that valve closed I can open a grey and the black to equalize the to tanks, I can open the the grey valves to equalize them.
All it cost was 2 valve flanges, another drain valve and a small can of ABS glue.
Cut the line into, glue on a flanges and bolt in new valve.
No pump needed, no power to run to pump, no added draw on battery......simple.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
