TakingThe5th
Apr 01, 2014Explorer
I have a similiar setup (and problem) with slightly smaller tanks on my rig. The dealer installed a grey water flush system in our new 5er that allows me to flush the toliet with the bath grey water. It works great, no smells or clogs, and I also save an equal amount of fresh water. Now, at the "end of the day" all my waste tanks are equally full and I'm out of fresh water. That to me is a nicely balanced system.
The system is simple. An extra pump and filter are installed feeding off a tap in the grey water tank. There are also valves and check valves and a switch which allow me to flush with fresh water if I prefer.
I also have the waste valve setup described in previous posts which I can use to balance the grey water tanks.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
