TheKunkels's avatar
TheKunkels
Heat water
Howdy to all.
Our CG shuts off the water during winter which I understand.
We use the CG showers. But every now and then the wife wants to soak in the tub in our tt. I can get pails of water if I want and heat water on the stove ( and use gas ) and dump in the tub for her. I was thinking of heating a couple metal 5 gal buckets on the fire pit and dumping them in. Some work involved but manageable. Does anyone have any better ideas they can share. I thought of storing water in a 55 gal barrel and use a sump pump to fill the small tub. Heat a couple buckets over the fire and dump them into the barrel then pump with the pump. Will hot water damage a sump pump.
Thanks guys and gals.
God Bless †
  • You'll tote buckets of hot water so your wife can take a tub bath? That's love... ;)
