ajriding's avatar
ajriding
Explorer II
Aug 14, 2019
Heave-Ho
A few photos removing the fridge. It was too big to fit through the door so the window had to come out.
Removing the window is very similar on 99% of RVs. It is pretty easy depending on what the previous guy used to seal the window. Use a scraper to pry the window free gently. The most common, and I think best, is the butyl tape. Most will use 3/4 inch tape. Clean RV and window frame before re-install. It is a sticky almost clay-like roll of thick goo that you roll out onto the window frame and stick the window back in. When you screw the window in the goo oozes out a little and you trim that.
Disconnect propane, unplug electric, unscrew fridge from cabinet and pull it out.
The window is out. I wish I could have just opened the window, but had to completely remove window.
I protected the RV with some thick towels
The long ladder gave me a nice ramp to slide the fridge out.
I just slid it down the ramp.
I will install a roof AC soon, and will use the ladder as a ramp to just slide the AC unit onto the roof. I have a hill the ladder is sitting on that helps even the elevations, but you could sit it on a table, or extend the ladder longer for a less-sloped ramp.
I have a DC powered compressor fridge that I will be using, and it is not particular about level, and will use free solar power…
I can share that install later. I plan to put it on the dinette seat next to the fridge area, which will become a closet, and have it on drawer sliders so the couch can still become a bed if needed. I do not need a full couch that often
  • I can see the pictures just fine.
    Good luck on your project.
  • Your pictures are not showing because you need to be a member of that forum to even view those pictures. Here is an easier way.
    If you will follow these directions exactly, it is very easy to post pictures on our forums. One of our moderators, 1492, developed this photo posting app to post your pictures. It works for other internet sites also. There is no need to have a separate hosting site for your pictures in order to use it.
    It is very simple to use.
    1. Upload your picture from your computer to the app.
    2. Copy the resulting URL.
    3. Paste that URL into your post
    without ANY changes
    . No additions or deletions.
    Your picture will then appear in your post and be properly sized for use on our forums.:)
    Barney
