profdant139's avatar
profdant139
Explorer II
Jun 14, 2013
Heavy Duty Trailer Jack Caster Wheel
The little stock plastic wheel was not doing the job for me -- we camp on soft dirt and rocky soil, and the wheel would either sink in or would be unable to roll over pebbles. So I decided to make my own -- here is the final product:
And here is a blog entry with more details:
Blog Entry: Custom-Made "Boondock Style" Heavy Duty Jack Caster Wheel
We'll see if this "improvement" is really an improvement, but I had fun doing the project, anyway.
  • BarneyS wrote:
    Is your trailer small and light enough to move it around by hand without using the tow vehicle, especially in sand, gravel, or grass? If not, then I cannot see the reason for the wheel instead of a regular pad. Just curious why you needed a wheel.
    Nice job by the way! :)
    Barney
    I find that it makes hooking up easier. Boondocking, I place a 2' leveling board under the wheel which I position at right angles to the axis of the trailer. That give me some left/right wiggle room to position the tongue over the ball.
    LS
  • Is your trailer small and light enough to move it around by hand without using the tow vehicle, especially in sand, gravel, or grass? If not, then I cannot see the reason for the wheel instead of a regular pad. Just curious why you needed a wheel.
    Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,389 PostsLatest Activity: Jan 20, 2025
