Blacklane
May 17, 2015Explorer
You can use the approaches listed above (adding a switch or a second thermostat), but Coleman makes a thermostat just for this application: Model 6536A3351
It has "gas heat" plus "electric heat" switch settings.
As stated above, you still need the extra wire from the thermostat to the A/C unit. That's sometimes easy to do, and sometimes not. Thankfully, my RV had an extra wire in the existing thermostat cable.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 14, 2026
