Cptnvideo
Jan 20, 2023Nomad
You might be over-thinking things. Likely the biggest amp draw from your 2000 watt inverter will be when you run the microwave and that would only be for a few minutes.
If you're planning on running close to the max on your inverter, you should probably go with a pair of the 206 ah SOKs. 200 ah won't last very long with the inverter running at full bore.
BTW, I have 5 of the 206ah SOKs. $1030 from Amazon or direct from SOK.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
