motorcycle_jack
Mar 20, 2014Explorer II
Unyalli wrote:
Ok, so looking at the picture of my hot water heater plumbing I would install a T in the incoming blue line at the bottom left. Then install a T in the hot water line up near the faucet. Now run a new line between these T's with a one way valve allowing the hot side access to the cold side. Yes?
Yup, you got it. The water in the tank is heated and rises in the feed line and as it cools it falls to the intake port of the hot water heater SO you have hot water at the faucet all the time. You might want to insulate the hot line to the faucet.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
