n0arp's avatar
n0arp
Homemade Tire Scale
I'm not really sure what forum this best fits in, so posting it here.
I assembled a 20K tire scale for around $300, which I consider a great tool to have if trying to tune and balance your rig. I use it for my truck, Jeep, truck camper, and fifth wheel, but it could be used for just about anything. And loan it out to friends.
It's built using a "livestock scale kit" with 4x5000lb load cells. The kit vendor is shown on the photos, and cost (at my time of purchase) $229 with free shipping. I used a cheap 1/2-13 tap off Amazon and the included bolts to mount it to a piece of 14x16x3/4" 6061 aluminum plate I purchased from an online metal distributor for around $80.
I calibrated it with 100lbs of dumbells, and have confirmed it reports values in-line with CAT scales at over 6K per tire.
My original setup had the load cells flush with the plate (you can see the old mounting holes in the bottom photo) but I moved them further outboard so I could run the feet up for a lower overall height (around 4.5") and allow for the load cells to fully flex without hitting the plate (which wasn't an issue at the weights I've tested, but might be towards the upper limits - say a class A DP rear). To get the most accurate readings, I've been using Lynx leveling blocks under the other tires so they're all at the same height as the scale. I've also used pairs of those blocks to ease driving on and off of the scale, and yes, you can put duals on it though they'll hang off the side.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Oct 12, 2025
