SoundGuy
Jul 19, 2016Explorer
jjrbus wrote:
I am progressing a bit with this and neglected to get some before temps on the honda. There are 2 kazillion articles on the web and I can not find one with operating temps. I know they are there I have saw them! Anyone have temps or a link?
Here is the humble beginnings a muffler extension and a aluminum box.
Well it would seem you didn't take advantage of those links I provided earlier because if you had one of them led directly to jauguston's rv.net forum discussion about the engineering principles that led to his own EU1000i quiet box design. In that discussion he also talks about temperatures inside the box. Secondly, in looking at your pic it's clear that by not sealing tightly against the genset's exhaust bezel you're not recognizing the importance of keeping cooking intake air, hot engine air, and hot exhaust gas completely separate from each other. It's a common mistake, one that those with an open frame generator can't avoid, but one you can avoid if you follow jauguston's design parameters. I did and as a result I know his reasoning is sound.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
