jjrbus
Jul 19, 2016Explorer
I did follow the link and it is greatly appreciated. HE shows the mixed exhaust temperature at 190°, I have no way to measure exhaust and then He gives temperatures inside the box. I was looking for actual case temperature of the Honda This is the humble beginnings not the end product. It may not show in the picture But I am separating the engine exhaust from the cooling air exhaust to have a future venturi type exhaust riser. Mine will be mounted on the camper, not portable. I am also adding the fans, if I do not have to use them would be ok!
At the moment I am experimenting with card board templates to make sure I have enough area for free air flow. One thing I have noticed is the box gets fairly hot on the bottom, which seems really odd?
Great ideas and truly appreciated the input! Jim
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
